Browse Forums Building Standards; Getting It Right! 1 May 19, 2010 1:40 pm Hi everyone, im in the process of building my first house and have noticed an bit of an issue with the colourbond posts that are holding the front verada up...there must have been a discrepancy with the height of the colourbond posts that are supporting the front veranda when they were erected, because the poles are obviously not long enough and have therefore been propped up by a sort of Gyprock or similar material. I have contacted my builder in regards to this concern and they have advised me that this is ‘common practice and the posts just need to be bolted’. Does anyone know if this is true? photos are here http://s781.photobucket.com/albums/yy97 ... struction/ Any help would be appreciated thanks. Adam Homestart - Belvedere Hills - Wanneroo Re: Colourbond post supports? Doesnt seem right.... 2May 19, 2010 1:44 pm Adam-is there a concrete slab to go in for the verandah? Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Colourbond post supports? Doesnt seem right.... 4May 19, 2010 1:49 pm I would assume that a concrete pad will be done underneath them before any bricking-just confirm this with your builder. You have photos as proof if there are any problems down the track. Best of luck! Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5876 Yes i guess this is one of the main reason as i checked one post foundation 4 9994 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8507 |
