Browse Forums Building Standards; Getting It Right! 1 Mar 03, 2010 5:52 pm Hi, We're about to move into our newly completed house and I am/was planning to build a timber deck for the alfresco area which will also run along the back of the house so you can step out from the bedroom and rumpus room onto the deck. All up the deck will be about 55 m2. I'm building in the Ipswich City Council area and after speaking with them...although I could use the term pulling teeth they have advised that I will need to get approval as the deck is great then 10m2 (which is rediculous) The issue I will have is that the house is a low set brick house and they advised that the clearance from the lowest timber member to the ground needs to be 450mm. How can I overcome this issue without creating a huge water pit under the deck or having to insert ag pipe for drainage. The alfresco area will be undercover but either side of that will be exposed. How do these display homes get away with building these floating decks that sit on the ground or just above it? Re: Deck clearance 2Mar 05, 2010 7:50 am If the subfloor timber is H4 grade then the clearance height shouldn't be an issue. 10m2 is fairly standard with most councils. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Deck clearance 3Aug 25, 2012 9:37 am sure it wasnt 150 mm? leighton clark new homes. PM me if you still not sure Re: Deck clearance 4Aug 29, 2012 1:28 pm leighton sure it wasnt 150 mm? leighton clark new homes. PM me if you still not sure 450mm is the standard to allow a person to access the underside of the deck for maintenance/cleaning/access. That means from the ground to the underside of the bearer. Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 1913 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9617 I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5709 |
