Browse Forums Building Standards; Getting It Right! Re: Brick Mortar 22Feb 27, 2010 9:15 pm nemisis - ...and single skin walls need an admix to aid shedding and reduce ingress. Where you are coming from is where you are going to... Re: Brick Mortar 23Feb 27, 2010 9:18 pm Thanks, Casa. Good it's a rendered house, and double brick. What if it was a brick veneer house, how can articulation joints be removed after bricking (if they can)?! My signature is distracting people from my wise posts ... Re: Brick Mortar 24Feb 27, 2010 9:38 pm Casa2 My application is that there was an internal articulation joint placed when there should be none. Now I'm looking for a way to link the two wall halves. why would you do that? there joined anyway with pins or Brick ties Re: Brick Mortar 28Mar 12, 2010 1:37 pm Casa2 So 6:1 and detergent is sounding very bad. Any ideas what will happen over time? the reason they put detergent in the cement is so it stays softer for longer and it's nice towork with (smoother, a little). 6:1 is too weak. (too much sand) 4:1 normally equates to one 20kg cement bag in a mixer and 16 shovels of sand, that's the best. Dishwashing detergent will weaken the mortar and you'll find it falling out of joints in years to come. easily fixed though. before you sell that house, just go and patch all the holes up. Re: Brick Mortar 29Mar 12, 2010 5:03 pm nemisis Casa2 So 6:1 and detergent is sounding very bad. Any ideas what will happen over time? the reason they put detergent in the cement is so it stays softer for longer and it's nice towork with (smoother, a little). 6:1 is too weak. (too much sand) 4:1 normally equates to one 20kg cement bag in a mixer and 16 shovels of sand, that's the best. Dishwashing detergent will weaken the mortar and you'll find it falling out of joints in years to come. easily fixed though. before you sell that house, just go and patch all the holes up. Not a good start for a brand new home. Wonder what project builders generally use. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Brick Mortar 35Mar 12, 2010 11:11 pm Lex Shouldn't the mortar requirements be specified in BCA / AU Std's? Exactly, but what happens in practice (at least in my case) is a different story. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Brick Mortar 36Mar 13, 2010 6:46 pm Not really. It's all down to the bricklayer(s) who get the job. If the Brickie is supplying the sand, he may choose a higher ratio (better for his pocket). I've heard of some supervisors telling brickies to pull down all the walls they've built when they saw the detergent bottle. I was a brickies labourer for 2 years and we used to use it on hot days....but I always mixed 4:1 ratio... Re: Brick Mortar 37Apr 19, 2010 2:15 pm The 6 sand ratio is a compromise between elasticity and compression strength, to allow for movement, less than 6 will reduce the ability to take up movement. Lime is added for workability during placement, but primarily to add a property know as autogenous healing to fix hairline movement cracking, detergent is a non approved additive and reduces the mortar strength dramatically, it does however improve workability, hence its use. if the specification is not met you don't accept it, its that simple, you can have it tested by a independent chemical engineer cheaply. Confiscate the detergent immediately!!! Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4569 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19134 2 8861 |
