Browse Forums Building Standards; Getting It Right! 1 Feb 15, 2010 1:03 pm Hope someone can help me! We have specified 450mm eaves, which are shown on our plans, however the frame seems to be incorrect! When we went to look at our frame last week we noticed that the eaves were not extended onto the roof trusses down one side of the house. My builder says that they will all extensions to each of the trusses down the side of the house for the eaves. Is this acceptable? Will the extensions be structurally sound? Building Monaco32 with Carlisle Homes in Alamanda Estate 20/08/2010 - HANDOVER 24/8!! Blog - http://ourmonaco32.blogspot.com/ Thread - viewtopic.php?f=31&t=14415 Re: Extending Frames to add Eaves 4Feb 15, 2010 5:14 pm One of the other parts of the problem is that they have done some of the parts with eaves (back of the garage and side of the alfresco). It is only about a 15m long section along one side of the house which does not have them. Building Monaco32 with Carlisle Homes in Alamanda Estate 20/08/2010 - HANDOVER 24/8!! Blog - http://ourmonaco32.blogspot.com/ Thread - viewtopic.php?f=31&t=14415 Re: Extending Frames to add Eaves 5Feb 16, 2010 10:13 am sarahq Hope someone can help me! We have specified 450mm eaves, which are shown on our plans, however the frame seems to be incorrect! When we went to look at our frame last week we noticed that the eaves were not extended onto the roof trusses down one side of the house. My builder says that they will all extensions to each of the trusses down the side of the house for the eaves. Is this acceptable? Will the extensions be structurally sound? If the rafters extend past the wall framing to provide an overhang then the builders will fix a soffit bearer to the end of each rafter and then to the stud. The soffit bearer is normally 45x32mm. This is then all boxed in with the fascia and the lining board. Re: Extending Frames to add Eaves 6Feb 17, 2010 6:36 am If I'm reading your post correctly you are saying that the top chord of the truss does not extend out to the eave line. An 'outrigger' can be nail laminated or bolted to the side of the chord to extend out the required distance. This can be done where the trusses have been ordered incorrectly or an error has been made onsite & the tails cut off by mistake. The spliced timber needs to backspan up along the truss a sufficient distance to allow the cantilever to take the load to the eaves line & should really be documented by an engineer or the like to ensure structural capabilities. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Extending Frames to add Eaves 7Feb 18, 2010 1:22 pm ausdesign If I'm reading your post correctly you are saying that the top chord of the truss does not extend out to the eave line. An 'outrigger' can be nail laminated or bolted to the side of the chord to extend out the required distance. This can be done where the trusses have been ordered incorrectly or an error has been made onsite & the tails cut off by mistake. The spliced timber needs to backspan up along the truss a sufficient distance to allow the cantilever to take the load to the eaves line & should really be documented by an engineer or the like to ensure structural capabilities. That is exactly what I mean! Sorry I didn't explain it very well as I don't really know the technical terms. It seems that the builder has extended the chord of the roof truss out to the required length. It seems to overlap by about 1 - 1.5m, which shoudl be sufficient distance to allow the cantilever to take the load. We are asking the SS for some indication that the truss engineers accepted this design change. It seems to me like they ordered the wrong size trusses for this section.... Building Monaco32 with Carlisle Homes in Alamanda Estate 20/08/2010 - HANDOVER 24/8!! Blog - http://ourmonaco32.blogspot.com/ Thread - viewtopic.php?f=31&t=14415 If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5693 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1793 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 8365 |
