Browse Forums Building Standards; Getting It Right! 1 Jan 31, 2010 8:47 pm Are there requirements of how close you can build/extend the front of the house in relation to the front fence? Does there need to be a minimum requirement of the distance between the front fence and fromt of house? If so, is it set by the state or each local council? I have an existing house and would like to extend the carport - turing it into a double brick garage. I would like to extend the garage towards the front of the property, however am unsure how far I am allowed to extend. Any advice would be appreciated. Re: Requirements of front of house from front fence (Vic) 2Jan 31, 2010 9:13 pm Agetal Are there requirements of how close you can build/extend the front of the house in relation to the front fence? Does there need to be a minimum requirement of the distance between the front fence and fromt of house? If so, is it set by the state or each local council? I have an existing house and would like to extend the carport - turing it into a double brick garage. I would like to extend the garage towards the front of the property, however am unsure how far I am allowed to extend. Any advice would be appreciated. ResCode (VIC regulations) state the minimum distance is 9m or the average of your neighbours' setback, whichever is the lesser. You can apply for dispensation through your local council. Phone your local council to check the process and the likelihood that a variation would be passed. Re: Requirements of front of house from front fence (Vic) 3Jan 31, 2010 9:22 pm Depends on your council. You sound like you're in an established area? Like Trinity said you should be able to build up to your neighbours' setback... however in some cases if you have written consent from your adjoining neighbour/s that they dont mind, then you might be able to build infront of their setback. End decision will come down to council's. Re: Requirements of front of house from front fence (Vic) 4Feb 03, 2010 12:59 pm Under Vic regs the setback hasn't altered as far as I know from 6 met. on a 'declared' road & 4 met for streets etc. (subject to planning provisions). If there are neighbouring properties then the average setback of those up to a maximum of 9 met. i.e. if neighbouring homes are both setback 10 met you are only required to go to 9 met. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3644 I'm wondering if anyone knows what the requirements are of a builder to be eligible to hold Domestic Building Insurance for proposed works. https://www.dbi.vmia.vic.gov.au… 0 3324 Old Home Restoration / Renovation Try your local council. They should be able to advise in regards ownership of next door dwellling and give advice as to what steps you have to take before doing any work 1 9790 |
