Browse Forums Building Standards; Getting It Right! 1 Dec 15, 2009 6:48 pm Hi, We are currently building with Simonds homes and our garage has 2 rollerdoors, Double in the fron and a single in the back. The back wall was only done single brick as i heard, it has to be double brick around the roller door to support it. They then blamed the engineer who did our plans and told us they sacked him and took them 3 weeks to make a decision on what they needed to do on you garage as they couldnt put 1 extra layer of brick as the kitchen window joins the end of the garage. Finally they cut 2 timber frames near the opening of the door to fit 1 extre line of bricks there. Is this legal? Im a bit worried they cut part f the frame.... ALso can we recieve reimbursment back as it wasnt built correctly.... Has anyone had this same problem? Re: Faulty Brick work to our Garage 2Dec 15, 2009 8:17 pm i would be asking them to provide a copy of the drawings for the new works that they have just done & also a copy of the engineers approval for it to be carried out how they did it i would also employ an independant Building Inspecter to check out how the works were carried out cheers rocket Re: Faulty Brick work to our Garage 3Dec 16, 2009 11:40 am Yep, get Kev or Alex on it asap!! And get it all in writing, eg. even if it's been a while since you talked, just send them a summary email, refer to your conversation ... take pics, keep diary, etc. Be detailed. I wish you best of luck, and keep us posted please! My signature is distracting people from my wise posts ... DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1105 DIY, Home Maintenance & Repair Hi all I've got a brick garage/shed at the back of my house. It's been hit at some point (before I owned it) and has a large crack running down through the bricks. I want… 0 8752 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 |
