Hi
We are building in Forde, ACT. Our frames just went up and I've seen some things, which don't seem right.
1) Some frames cover the floor waste pipes, so the plumbers are now cutting them to get access. This doesn't seem ok.
What should be done here instead? If they cut the frame at the bottom, should they put some reinforcement back somewhere above the cut?
2) The frame which forms the back wall of the garage just hangs in the air in the middle and overhangs by more than half of the with on the other end.
surely this cannot be right?? Is the builder supposed to put something under the frame - ie bricks or angle bar bolted to wall and frame?
Also attached is the floor plan. Highlighted is the hanging frame.
