Browse Forums Building Standards; Getting It Right! 1 Sep 18, 2009 6:53 pm Hi all Firstly i would like to apologise for posting a question before even introducing myself. I have been waiting patiently and was wanting to makes posts once we started building, however I need some help before that can happen! We will be signing contracts with our builder Rivergum on Monday and I have a questions relating to eaves. The house we have chosen includes 450mm eaves all around. The question i have what is the actual distance from the Border that I can have eaves without being cut back due to lack of natural sunlight? To put it in a scenario - on the east side of our house we are building 1400mm from the Fence, this causing the eaves to be cut back 3/4 of the way due to the lack of lighting going into a bedroom. I have confirmed with another builder, and they have mentioned the minimum to have full eaves would be to build 1500mm from the fence. However, Rivergum have said that the minimum is 1650mm (odd number?). This is really convenient for Rivergum as this means that we can not move our house further to the West side as we will be 50mm to close to the other fence. So can someone please confirm what the exact distance is required to have full eaves. Hope the above all makes sense! Thanks, Dan Re: Eaves, Regulations and the Border 2Sep 18, 2009 9:42 pm My house is 1 meter from the fence and I have full 450mm eaves. My fence is going to block out more sun than my eave. Re: Eaves, Regulations and the Border 3Sep 21, 2009 3:55 pm Referring to the BCA 3.8.4.2 says that Natural light must be provided to every habitable room by windows that are not less than 10% of the floor area of that room and are open to the sky face a court or open verandah or carport or the like. If the window faces the boundary of an adjoining property it must not be less than 900mm horizontally from the boundary! Nothing stated about size of eaves! Eaves are allowed up to 450mm off boundary to fascia for fire rating so long as they are non combustible eave lining and non combustible roof material. Fascia may be timber. 3.7.1.7 (figure 3.7.1.9) All this said, if the plan has been passed with 450 eaves make sure you get 450 eaves! Make sure you get the builder or site supervisor to look this up in the BCA, every builder should have one. Hope this helps, Michael The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7872 If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26171 You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed. 1 1834 |
