Browse Forums Building Standards; Getting It Right! 1 Jun 10, 2007 10:16 pm Does anyone have a copy of this or have read it. Specifically I'm after the hearth construction details. Bear in mind this was updated I think in 2001 - I'm aware of the brick or fibro/metal sheet methods. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5202 |
