Browse Forums Building Standards; Getting It Right! 1 Jun 10, 2007 11:16 pm Does anyone have a copy of this or have read it. Specifically I'm after the hearth construction details. Bear in mind this was updated I think in 2001 - I'm aware of the brick or fibro/metal sheet methods. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 2548 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 3058 ![]() DIY, Home Maintenance & Repair Thanks for your input. It is a skillion roof carrying both ceiling and roof loads. I didn't think of LVL so I will look at this option. I will be screwing timber into top… 2 3814 |
