Browse Forums Building Standards; Getting It Right! 1 Sep 06, 2009 2:07 pm Hi all, Does anyone know if there is a problem using water from a rainwater tank that is already connected to run toilets and washing machines? I have had two different opinions, one says that you cannot have another outlet on a tank that is connected to toilets, the other said there is no problem. Thanks for the feedback Re: Use of recycled water in Victoria 2Sep 15, 2009 12:04 am I was hoping someone else would reply first. I'm not aware of any such regulation. Your not getting confused with the 'non return valve' that gets fitted if you are connected to a town supply? Re: Use of recycled water in Victoria 3Sep 17, 2009 6:38 pm Thanks for the reply, no I'm not confused about the valve, I was told that you couldn't draw water for use in a garden, wash the car etc, from the same tank that is connected to the toilets / laundry... Hope this isn't so, I'm plumbing them in together next month.. Re: Use of recycled water in Victoria 4Sep 18, 2009 8:09 am luckygrizzly Thanks for the reply, no I'm not confused about the valve, I was told that you couldn't draw water for use in a garden, wash the car etc, from the same tank that is connected to the toilets / laundry... Hope this isn't so, I'm plumbing them in together next month.. I believe you are correct. If the tank is connected to mains water then it can only be used for internal use. Hope this helps. Re: Use of recycled water in Victoria 5Sep 20, 2009 7:30 am If the tank is filled from the mains it is really not a rainwater tank Quote: Thanks for the reply, no I'm not confused about the valve, I was told that you couldn't draw water for use in a garden, wash the car etc, from the same tank that is connected to the toilets / laundry... Hope this isn't so, I'm plumbing them in together next month.. Sounds like a load of hogwash (assuming the tanks are filled from rainwater that is!) Re: Use of recycled water in Victoria 6Sep 21, 2009 3:39 pm That's correct, you cannot use your tank for external applications if it is plumbed into the house. (well you can if you dont tell everyone...not that i condone this) You will have a low level sensor that switches to mains water when low (often via the tank) and as such if the tank is low you would be watering the garden with mains water not rainwater. Re: Use of recycled water in Victoria 7Sep 22, 2009 12:25 am Thanks mrh20, I wasn't aware of that. Do you know if it's a plumbing code reg or water company rule. You're right in that the watersaver switches automatically from tank to mains with a light inside the front panel to indicate when this is happening. So if you have a plumbed in tank you have to be physically prevented from using mains water on the garden but if you don't have a tank the authorty is happy for you to use your own judgement. My solution to catch excess water users is to fit every house with a meter to see how much they use.? Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10909 For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9093 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20889 |
