Browse Forums Building Standards; Getting It Right! 1 Jul 17, 2009 9:28 pm im very worried about this........http://s677.photobucket.com/albums/vv132/zaphod373/ Re: mortar? with pics 2Jul 19, 2009 6:24 pm Yep…looks a little nasty! But I have to say, your bricks don’t look very even to start with, even so, they did a rough job laying them. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: mortar? with pics 4Jul 19, 2009 6:41 pm our bricks are the same in some places... we just figured they had to space them a little to make the space. I would rather a bit of a wide gap in the mortar than tiny little pieces of brick stuck in there.. ( but I am certainly no expert on bricklaying lol) -Sha Re: mortar? with pics 5Jul 19, 2009 6:43 pm Brickie Zaphod we get it, multiple posts of the same stuff doesnt make it any better or badder 1 post is enough. So do you have a comment about the laying? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: mortar? with pics 7Jul 19, 2009 7:06 pm sha our bricks are the same in some places... we just figured they had to space them a little to make the space. I would rather a bit of a wide gap in the mortar than tiny little pieces of brick stuck in there.. ( but I am certainly no expert on bricklaying lol) -Sha Pictures? Re: mortar? with pics 8Jul 19, 2009 7:14 pm Zaphod….you might want to limit your amount of placements of your question, it gets to confussing otherwise. Thanks. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: mortar? with pics 10Jul 25, 2009 11:09 am Wow So much to learn. Sorry to hear you not happy with the work looks a bit average. May I ask on the photos who put the sticker lables with the writing on them. Was this left by you for the brick layer to read? Brickie may be able to inform us what the tolorence is for the mortar gap I think its 6 to15mm for the downward one (forgoten the name of it) that would help too brickie. Cheers hope things get sorted for you. KW................ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: mortar? with pics 11Jul 25, 2009 11:19 am I just had a better look at the pix. I would also like to hear Brickies oppinion can you please link me to the other post re. same subject. I feel the work is a bit average, Im not a brickie and would like to see mine better than this. Are you with a project builder? May I ask who is you dont mind? Cheers KW............ “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: mortar? with pics 12Jul 25, 2009 1:32 pm King Willy type in the username and it will come up with all the other threads. Brickie has commented several times in these threads. Check them out anyway. Re: mortar? with pics 13Dec 28, 2009 4:27 pm While not the best layed bricks, I think you have been a bit "picky" In some cases there is not a lot that can be done especially on the brick and a half return.. where they have spread the perps to hit the windows frame.. really the window has been installed incorrectly and no to brickwork in this case. Brickies will usually move these if they have only been tacked in place. I certainly hope you didn't leave those notes for the bricky to find the next day...not a good way to get a tradesman on side. I can tell my subbies if they have done crap work but they have been working for me for years..... Re: mortar? with pics 14Dec 30, 2009 4:59 pm hi striking, the builder would not have pulled down several walls if we were being a bit picky, they would have stated that the brickwork was within the standards and left them alone. The brick and a half problem which you mention, starts at the bottom ok, then gets progressively worse. this has been redone now, and was not caused by the window, which you suggest. It is simple striking, if the work is not within the standards it is a defect and must be brought up to the standards, wouldn't you agree? Re: mortar? with pics 17Jan 04, 2010 9:56 pm Not sure what state you are in but the Victorian Building Commission has the guide on Standards and Tolerances that would be the best place to start any judgement. You can download it here: http://www.buildingcommission.com.au/resources/documents/S+T_GUIDE_07.pdf You will see on Table 3.04 very detailed descriptions on what is acceptable and the 5mm - 15mm rule is pretty much on the money. Builders are people too.... Re: mortar? with pics 18Jan 05, 2010 8:54 pm For sure, it needs to be to the standard, I was just trying to be the devils advocate, I see it so often the people expect perfection when it just isn't the standard. It was difficult to seen the photos and I am sure it looked much worse in real life. keep in mind the standard is only the "minimum" requirement and a goods tradesman and or supervisor would expect far greater.... I have worked hard with my trades over the years to get them to a standard I am happy with. Chris Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4604 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19210 2 9205 |
