Browse Forums Building Standards; Getting It Right! Re: Building a front bricked boundry fence. 7May 15, 2009 2:31 pm Pat the draftie rallliart888 I spoken to my local council (City of Wanneroo) and requested for an application form and specifications. There is one thing I am not clear about is what is the max or min width of the wall between the piers/pillars? On the specification is says that the piers has to be centered at 2700mm in between. My two cents worth: The pier spacings are not a council regulation. The pier spacing is determined by a structural engineer, who calculates this based on the wall height and the wall lenghts. 2700mm might be a maximum spacing, there is no reason why you could space them closer togeather to get a even number of piers along your boundary. Pat. Pat thanks for that info. Old Home Restoration / Renovation Try your local council. They should be able to advise in regards ownership of next door dwellling and give advice as to what steps you have to take before doing any work 1 9796 I recently finished my house and after landscaping, have begun to plan a fence. To be honest its been a bit of an afterthought so I'm after some much needed advice. The… 0 2017 Building a fence now will help limit people dumping rubbish and soil on your property. Many houses in suburbia on small lots have fences up before a build. I moved into a… 1 4396 |
