Browse Forums Building Standards; Getting It Right! 1 Apr 29, 2009 11:41 am Is someone able to point me in the right direction for this. There is a property we are interested in which has a very large storage room next to the garage, the room doesn't have any windows at present. I assume windows are a requirement for a room to be called a bedroom. Can someone tell me what size the window has to be and if there are any other requirements? Re: Building standards for converting a room into a bedroom? 2Apr 29, 2009 2:47 pm The BCA states that all habitable rooms have a minimum window size of 10% of the floor area of the room, and that this window have an opening element for ventilation purposes of 5% of the floor area of the room. You might want to consider your breeze paths as well, Part J of the BCA indicates that all habitable rooms maintain a breeze path through it, ie on a hot day you can open all your windows and doors, and get the hot air purged away through natural cross ventilation. Pat. Re: Building standards for converting a room into a bedroom? 3May 03, 2009 4:44 pm ....and the floor if it is a concrete slab has to have a waterproof membrane. The ceiling height needs to average 2.4 or better. The walls need to be configured 'to prevent the ingress of water' etc. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. start from at least $20,000 just for fixtures and finishes and then add on for moving plumbing and extra for a concrete floored house last new bathroom we installed in a… 1 19593 2 9459 If I hire a contractor to convert a window to a sliding door will I need to show them Council approval paperwork? That is, if I want to take a risk of carrying out the… 0 13011 |
