Browse Forums Building Standards; Getting It Right! 1 Feb 12, 2009 4:29 pm Hi guys
I have received advice about rendering that suggests that you should leave 10cm clearance from the ground and the render. What do you think of this? And, my friend also said that the edge of the render should have scaffold to help prevent water getting behind the render. What does he mean by scaffold? I couldn't find anything in google in regards to render & scaffold. Cheers Re: Damp behind render causing cracks 2Feb 17, 2009 3:37 pm Sorry, ignore this now as it was a house that I bid on at an auction and was confident at getting but I didn't even though it was a foreclosure and our limit was quite high (470k). It went for 501k. So I don't care about the render of this house now. It can fall right off if it wants. Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 6914 The mesh is often stuck on wall first then rendered over, which means it does nothing Not to specifications Get a scope of works in writing before start, needs to be… 10 9005 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20580 |
