Browse Forums Building Standards; Getting It Right! 1 Dec 01, 2008 8:33 pm Hi everyone,
Would one rainhead behind the garage enough? Rainhead at the front will affect the position of the light on the left of the garage. Is it okay to removed the rainhead at the front? Please help Thanks! Re: One rainhead enough? Please help 3Dec 04, 2008 5:24 pm Forget about 12m apart... It all depends on where you are in the country, what your rainfall intensity is, slope of your roof, and gutter size...
From there you can figure out what roof area needs to be serviced by a single downpipe, and therefore how many rainheads... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: One rainhead enough? Please help 4Dec 04, 2008 6:18 pm Or you could use this handy rainwater/gutter calculator;
http://www.roof-gutter-design.com.au/Downp/applet.php Regards, Pat. DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 6120 Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5985 As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 998 |
