Browse Forums Building Standards; Getting It Right! Re: Noisy steel frame house / floor creaks upstairs when walked on 14Nov 29, 2024 9:43 pm We are Expert Consultant's, and we are here to help. Re: Noisy steel frame house / floor creaks upstairs when walked on 16Nov 30, 2024 7:53 am I have just run a quick design check on that 4.5m span connected boxed beam B1 250x70x1.5 and it appears that the beam if adequately connected would run at 130% (failed) and provide over 60mm of deflection at maximum floor loads. This is serious and needs to be addressed by the builder engineer. Re: Noisy steel frame house / floor creaks upstairs when walked on 17Dec 01, 2024 9:59 pm Eng. B A I have just run a quick design check on that 4.5m span connected boxed beam B1 250x70x1.5 and it appears that the beam if adequately connected would run at 130% (failed) and provide over 60mm of deflection at maximum floor loads. This is serious and needs to be addressed by the builder engineer. Hi Eng BA, thianks for runing this through. May I please know if there is anyway to get in touch with you, we need this in document to report it to the builder. We have been really stressed about this because ths builder won't acknowledge our concerns, we need to get this documented. Building Standards; Getting It Right! Hi there, We have recently built a double storey house by Coral Homes, it is a steel frame house. When someone walks upstairs it cracks with every step and it is very… 0 4614 I've gone for pre-fab walls. I did it because I wanted to remove the idiot factor from the construction on site , control theft and reduce waste its supposed to be… 12 35602 it's difficult to make suggestions without accurate information as there are some inconsistencies in the dimensions as the length of the bedrooms is not equal to the… 3 13123 |
