Browse Forums Building Standards; Getting It Right! 1 Nov 06, 2024 10:36 am Hi all. I've recently had my bathroom, laundry and WC renovated by a builder. The bathroom was completely gutted and rebuilt from scratch. It has hobless shower (fall to waste chased into slab) with frameless glazing, an inset bath, and cavity slider door. The builder provided waterproofing certification for bathroom and laundry. My reading of the NCC and AS3470 is that such a wet area must have waterstops. I see no evidence of a waterstop at the edges of the shower, or under the bath flanges (either when completed or during the build). There may be one at the door threshold, but it's more likely to just be aluminium tule edging, as it provides no continuity of the waterproofing "tank". Are there any circumstances under which waterstops would NOT be required in a bathroom? Thanks. Re: Bathroom waterstop requirements 4Nov 29, 2024 9:32 pm You should have a waterstop at your shower and again at any entry to the bathroom. As the bathroom includes an unenclosed shower the main floor of the bathroom Must grade at 1in80 to 1in100 subject to shich code he has worked too. The floor waste is a Must as the bath requires a disconnector trap to provide a water seal to the main drainage line We are Expert Consultant's, and we are here to help. You can ask the plumber to run 2 pipes to you laundry. One connected to the mains and one to the tank ( i did this in my home) I find that if you just turn your pump off… 6 10899 Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 14936 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 31462 |
