Browse Forums Building Standards; Getting It Right! 1 Mar 07, 2024 6:25 am Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a room) with a 25mm gap between them, insulate both and use thick plaster. To increase the size of the room, can I frame with 70x45 timber instead of 90x45. The height of the room is 3100. Walls are non-load bearing Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3939 We planned a similar shower and ended up with a simple single shower with one glass panel walk into the shower at the end, much easier, dries completely between showers… 3 5948 STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 6030 |
