Browse Forums Building Standards; Getting It Right! 1 Oct 03, 2023 8:52 pm Hello, After opinions... builder is in disagreement with our building inspector on this. Windows in our new build to the meals area have been listed as a defect as "there is no evidence of a sill flashing being installed under the windows in accordance with NCC 2019 building code vol 2, 3.3.5.8". The code is weatherproofing of masonry, however the builder is saying that because it is up against concrete slab on not brick that this code doesn't apply. The inspector is requiring flashing. The two can't agree and the builder is saying they way they have done it is normal practise and that water can't get in as it is tiled from the outside. Pictures attached. Any advice would be great. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building defect - sill flashing under window on concrete 2Jan 31, 2024 12:47 pm There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have standards details for the waterproofing for this exact situation. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ For anyone reading this, they ended up putting brick sills under the window. 5 4497 DIY, Home Maintenance & Repair The intent of that sort of clause is being misaaplied. its suposed to be used to avoid paying out for things liek when you decided to do a reno yourself and the… 3 8300 I had a similar issue with my dishwasher not getting water, and it turned out to be a faulty aquastop. In my case, the mechanism inside was jammed, so no water was passing… 1 4359 |
