Does this look right? Is there anyone who can advise of seperation rules between water and electrical pipes in victoria?
I am no expert when it comes to regulations in Victoria.
Thank you
Browse Forums Building Standards; Getting It Right! 1 Dec 04, 2021 7:24 am Re: Water pipes to close to electrical? 2Dec 04, 2021 12:21 pm The above ground minimum separation requirement is 25mm. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 4 5121 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 |
