Browse Forums Building Standards; Getting It Right! 1 Nov 03, 2021 9:12 pm Long story short we hired a guy who does stratco insulated roofs. we were building a roof over our deck to comply to the exempt development guidelines but with a flyover roof that helps drain the water from the new roof on to the downstairs single level rumpus room gutters and then to the water tank. The guy after doing the beam over the single level roof said it was going to be a bit higher than initially expected height a bit closer to 3 from the deck height. once finished the highest point of the structure is 3.1m from the deck. We have paid the guy in full (of course) but now when I look at it everytime I am worried for the height. Is there a process I can follow in NSW to apply for a certificate to get this certified? ok thanks - yes was wondering if that should have been listed as Option Three! 2 7754 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8512 I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5720 |
