Browse Forums Building Standards; Getting It Right! 1 Sep 27, 2021 2:34 pm As part of the process of installing Hebel panels along the boundary, the builder next door caused various damages to the panels (ie cracks right through), plus the panels somehow had holes in them prior to installation (as I noticed it while the panels were on the ground prior to installation). The builder has decided not to apply any waterproofing (render to these panels) and in light of the above damage, I have obvious concerns. Plus I do not believe there is any damp proof course (not too sure if this is necessary). Are there any Australian Standards, and / or Building Code of Australia / National Construction Code requirements that the builder has breached in regards to the above installation, as the builder believes the above is perfectly acceptable? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Installation of Boundary Panels 2Feb 19, 2022 4:41 pm MelBr As part of the process of installing Hebel panels along the boundary, the builder next door caused various damages to the panels (ie cracks right through), plus the panels somehow had holes in them prior to installation (as I noticed it while the panels were on the ground prior to installation). The builder has decided not to apply any waterproofing (render to these panels) and in light of the above damage, I have obvious concerns. Plus I do not believe there is any damp proof course (not too sure if this is necessary). Are there any Australian Standards, and / or Building Code of Australia / National Construction Code requirements that the builder has breached in regards to the above installation, as the builder believes the above is perfectly acceptable? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, seeing if you have had these issues fixed? I'm currently having these issues with Soho living and they don't seem to care. Once my neighbors bricks go up there is no access to these cladding walls. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Installation of Boundary Panels 3May 03, 2022 6:43 am Kristie.vassiliadis MelBr As part of the process of installing Hebel panels along the boundary, the builder next door caused various damages to the panels (ie cracks right through), plus the panels somehow had holes in them prior to installation (as I noticed it while the panels were on the ground prior to installation). The builder has decided not to apply any waterproofing (render to these panels) and in light of the above damage, I have obvious concerns. Plus I do not believe there is any damp proof course (not too sure if this is necessary). Are there any Australian Standards, and / or Building Code of Australia / National Construction Code requirements that the builder has breached in regards to the above installation, as the builder believes the above is perfectly acceptable? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, seeing if you have had these issues fixed? I'm currently having these issues with Soho living and they don't seem to care. Once my neighbors bricks go up there is no access to these cladding walls. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Check this out. All the best for a easy resolution. https://www.consumer.vic.gov.au/housing ... and-delays Hello - we were hoping to apply laminate click lock panels to our concrete ceiling, but not too sure how to go about attaching the panels to the concrete. Any idea what… 0 691 0 2988 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 11899 |
