Browse Forums Building Standards; Getting It Right! Re: Damp proof course less than 150mm above adjacent groun 2Sep 17, 2021 7:41 am visvandev2 NCC 2019: - The DPC (damp proof course) must not be less than 150mm above adjacent ground level. Are you in a low intensity rainfall region and are some of the weep holes under cover? The full regulations are below. NCC-BCA V2 Class 1 & 10 3.3.5.8 Damp-proof course (b)The location of a damp-proof course or flashing serving as a damp-proof course, must be not less than— (i)150 mm above the adjacent ground level; or (ii)75 mm above the finished surface level of adjacent paved, concreted or landscaped areas that slope away from the wall; or (iii)50 mm above finished paved, concreted or landscaped areas complying with 3.1.3.3(b) (ii) and protected from the direct effects of the weather by a carport, verandah or the like; or (iv)in low rainfall intensity areas— (A)15 mm above finished paved, concreted or landscaped areas; or (B)0 mm above finished paved, concreted or landscaped areas if the damp-proof course is protected from the direct effects of the weather by a carport, verandah or the like. If the concreting is not compliant, it must be re-done. There is nothing to negotiate about this. Sometimes concreting is (still wrongly) too high due to the site cut resulting in an inadequate slab height but these planning deficiencies should be picked up pre slab pour. Unsuitable site cuts are also responsible in many instances for lack of proper stormwater and drain pipe slope. You should also have these forensically examined pre handover. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20614 Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 6346 Had a new driveway installed with a 6 metre long 150 x 150 channel drain and have since found out it has 4cm of water sitting at the bottom below the side pipe… 0 4726 |
