Browse Forums Building Standards; Getting It Right! 1 Aug 26, 2021 9:34 pm Hello, Our NSW block of flats has had some stormwater drains replaced. We are concerned that the work does not meet the PCA standards. For example, the pipes are just below the surface soil and are even visible when there is some light rain. There are also some concreting issues. We would like a consultation from a qualified specialist - but we need to know which type of consultant or surveyor to contact. Any advice would be appreciated. Thank you. Re: Need a consultant / surveyor to confirm PCA standards. 2Aug 26, 2021 10:30 pm It comes under forensic plumbing inspection/investigation. Google using the key words and your region. Companies who do this also prepare reports etc whereas a capable plumber who could easily do it (at less cost) won't usually prepare a report or want further involvement and will often refuse the job. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5356 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6996 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5145 |
