Browse Forums Building Standards; Getting It Right! 1 Aug 04, 2021 8:10 am Hello I have a sloping block and access to a rather large amount of clean fill from a neighbour’s block. I want to level this to create a flat area with a retaining wall. In future I would like to build a house on the flattened area. How far away from the retaining wall would the slab for the house need to be? Can I even do this in NSW, Australia? Thanks for the help Re: Build on built up block 2Aug 04, 2021 12:06 pm Hi Jessamat Welcome to the forum I suggest you put an application and engineering into the council for the retaining and fill This will save you removing it later if it's non compliant Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17587 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12743 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4193 |
