Browse Forums Building Standards; Getting It Right! 1 Apr 10, 2021 10:52 pm Hi everyone, we are in the process of building our new home... we are have just had the frames completed so i was eager to take a look. When arriving in site I noticed the fence was left open so i went and had a walk around. For the most part and according to our “ private inspection report “ everything was looking ok. I was shocked when I looked up and seen the roof truss being chocked up by some left over building material??? Its only in one section of the house by the bathroom but there are 4 sections on the top of the internal wall frame where it meets the roof trusses. Can anyone tell me what would be the reason this is like this and if it’s going to cause issues? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I said after the 1st build “ never again “ & now im on my 3rd Re: Can someone please explain what on earth is going on her 2Apr 11, 2021 9:37 am CD12JD When arriving in site I noticed the fence was left open so i went and had a walk around. For the most part and according to our “ private inspection report “ everything was looking ok. its only in one section of the house by the bathroom but there are 4 sections on the top of the internal wall frame where it meets the roof trusses. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That's a problem with truss inspections, thanks for the photo You don't know whether the member at the node connection (junction) is a strut (compression) or a tie (tension) As a rule of thumb internal walls are not to be packed -> connected internally to trusses You will need to check the truss and wall (ie hold down ties) engineering cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Can someone please explain what on earth is going on her 3Apr 12, 2021 1:02 pm The light guage steel frame is prefabricated offsite to some very precise design detailing software measurements and the walls and trusses should all fit together neatly like meccano on your slab. Steel does not warp and flex like timber. If there are gaps filled like the those pictured some mistakes have been made with the dimensions, prefabrication, or slab levels. I suggest asking your builder and your inspector to check the dimensions and alignment of all trussess and walls against your plans before your next progress payment and before its covered up with gyprock. With such a gap other things will be out of alignment. Better fix it now than wait until practical completion to find out when its too late to realistically fix and you have paid 90%. Re: Can someone please explain what on earth is going on her 4Apr 20, 2021 12:27 am Thanks for taking the time to reply guys... i will somehow have to raise it with the site supervisor without giving away i was onsite without permission. I will call the inspector who did the frame inspection and start off there. It looks to me as the slab is lower in that part of the house although this was just going off it by eye . I said after the 1st build “ never again “ & now im on my 3rd Thanks. I wish there was a youtube video explaining this concept. 10 27193 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105617 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14465 |
