Browse Forums Building Standards; Getting It Right! 1 Feb 13, 2021 10:10 pm Hello, From the CDC clause of Storey definition: Storey is defined in the Standard Instrument as a space within a building that is situated between one floor level and the floor level next above, or if there is no floor above, the ceiling or roof above In our case, we want to add an extra storey on top of what is already an existing Balcony. The existing balcony is 2.5m above grass. Will this make my development 3 storeys? Or the balcony and the grass area under it don't count as a storey? Thanks! Re: CDC - Does building on top of a balcony count as a STORE 3Feb 15, 2021 2:46 pm Hi Bimbob, It's a sloping land - yes some part of the balcony is 2.2m above Natural Ground Level, but some part of the balcony is just 1m above NGL. I think this is getting to the point where the CDC regulation is a bit grey, but i am interested to know why do you think 2.2m above NGL is counted as a storey and at which point is it not? Surely 1m above NGL is not counted as a storey. Re: CDC - Does building on top of a balcony count as a STORE 4Feb 15, 2021 2:53 pm is the balcony attached to the upper floor of a two storey house or a single storey house with land that falls away? The CDC is not grey, its exactly as they intended. As are the houses which are a product of the CDC. Re: CDC - Does building on top of a balcony count as a STORE 6Feb 15, 2021 3:40 pm Thank you for quick responses. Currently it is 1.5 storey house on a side sloping block.
Existing lower ground floor: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Existing Ground floor. Understand i can only build on top of the slab foundation part, but I am unsure about building on top of the balcony. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: CDC - Does building on top of a balcony count as a STORE 8Feb 15, 2021 3:46 pm Bimbob So the balcony is on the ground floor? Thats is the 1st storey. Building above it is the second storey Yes Balcony is on the ground floor, but note there is the garage in the "lower ground floor". That's why part of the balcony is 2.2m above NGL. HOWEVER the balcony is not on top of the garage, it is actually on top of an open space. So building above the Ground Floor Balcony is considered a second storey, not third? Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 4782 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8432 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4797 |
