Browse Forums Building Standards; Getting It Right! 1 Nov 29, 2020 6:45 am We have just bought a house and the lowest floor has a rumpus room which opens onto a concrete area. The concrete area is covered by the wood deck above so it gets wet when it rains as the rain come through the gaps in the board. We are thinking of tiling the concrete area - as this is on the ground floor I am aaauming it does not require waterproofing but wanted to check? Re: Tiling our concrete slab - waterproofing 2Dec 07, 2020 6:48 pm No it doesn’t require waterproofing if it’s external and on the ground. You need to make sure that once tiled, it remains below the internal floor height, and doesn’t allow water to flow towards the house or covers weep holes. Re: Tiling our concrete slab - waterproofing 3Jan 20, 2021 11:47 pm It may require waterproofing if it doesn't have a vapour barrier beneath. If you can't check or are unsure, then definitely waterproof it. If it's a newer slab, it will have one. You can tile it flush with your internal area, its just not ideal. Definitely be careful to not block weepholes. Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4702 I have researched this topic in detail recently but for another state which has no licensing requirements at all so any handy man can waterproof any old way and not have… 1 8562 2 8738 |
