Browse Forums Building Standards; Getting It Right! 1 Sep 27, 2020 3:14 pm I am planning a 10m2 ensuite extension to a brick veneer house with existing timber framed floor. However the area of extension has been built up level with the existing floor. I am proposing a slab, but I am aware it must be 150mm aove ground level, which will not work. Can I: A: Build in a drainage channel around the perimeter to achieve the 150mm. B: Excavate the surrounding area to below 150mm (with drainage) and if so, how far back will this need to extend. C: Build a brick veneer wall with bottom courses waterproofed D: Build a say 3 courses of brick, waterproofed inside and out, with a timber framed wall above (due to space consideration a single wall is preferred, if possible). Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one… 0 6532 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11756 |
