Browse Forums Building Standards; Getting It Right! Re: [Urgent] Advise please - Weep hole 25Jul 31, 2016 12:03 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: [Urgent] Advise please - Weep hole 26Jul 31, 2016 6:32 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7319 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5701 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11563 |
