Browse Forums Feng Shui 1 Nov 19, 2010 2:04 pm Hi, am new here, just bought a block of land facing north. Theres a storm drain on northeast of block (if youre facing from house). Water will drain into this inlet, then travel straight to house across the st, which has also a storm drain. Is this bad feng shui? Is my block not good? Re: Block has storm drain facing another storm drain 3Nov 24, 2010 9:54 pm ok, basically the way its designed, if there's flooding, water will flow from left side of the street (if im facing the street from my house) then drop to the inlet northeast of my house, then travel straight underneath across the street, so effectively water will flow towards my neighbor (across the street).. the drain in front of me is an inlet for houses on my side of the street...thus exit point... i wonder whats the effect on feng shui... Re: Block has storm drain facing another storm drain 4Nov 25, 2010 4:51 pm so i take it that - north-east is actually the right side of your house? water comes from the left, flows across your front to the right side of the house? Left is the dragon side, dragon needs water. water strengthens the dragon. YANG. generally ancient chinese loves houses that has a river/stream on the left side of their house, flowing from the rear towards the front of the house. Then a mountain behind the house, green pasture(empty greens) in front. some shrubs/woods/trees at the right. the perfect balanced house. nothing wrong with your plot of land with regards to storm drain. It doesnt have water all the time so the effects(good or bad) is very mild from that of a river/stream. Re: Block has storm drain facing another storm drain 5Nov 26, 2010 11:30 pm thanks, yes the drain is at the front of house (northeast), driveway will be on left side as council wont allow it on right side... since most of the time there isnt water, then i say not much effect really, its just a sore in the eye if youre looking in the house and theres a long drain at the front... better put up a nice garden in front to counter it... and of course future resale is a bit affected as some people dont like drain in front of house... Re: Block has storm drain facing another storm drain 6Nov 27, 2010 2:10 am Farrba and of course future resale is a bit affected as some people dont like drain in front of house... always emphasis on the good points..... or line up the frontage with a row of flowers? The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18451 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 20085 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7836 |
