Browse Forums Feng Shui Re: Seeing Straight through house 13Jun 02, 2017 7:29 am I also think it has something to do with the flow of the energy that usually starts from the front door. So if you front door directly leads to the backyard, then the energy does not stay within the house itself. I think you could counter the situation by placing decorative in the passageway to capture the energy in phases. Another alternative would be to place an ornament or structure in your backyard so the energy will flow around your backyard instead of leaving the house completely. yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7330 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38448 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17323 |
