Seeing Straight through house
From memory you can do a few things to combat this. Pictures and paintings on the wall of the hallway can slow it down and any type of screen or pot plant placed strategically can also slow it down.
The above is definitely not for certaian and just what I can remember. Hopefully someone more knowledgeable than me can help you out.
I am no expert , but this is what I remember about this. I think that the theory is the good energy flows in your front door then flows straight through the house and out the back door woth nothing to keep it in the house and slow it down.
Your memory serves you fine.
Remember that chi is supposed to be like water, the flow smooth and gentle. You don't want harsh rapid flows of water around your house, so you wouldn't want fast rapid chi flow either*. So generally having doors in line from front to back while may look stylish, is not suitable for Feng Shui. Try to have some offset to slow the flow down and allow it to circulate.
It does depend on the length of the house also. Generally the longer houses are ok to have this configuration because the chi has time to circulate before moving out as you have described.
* A related misconception is the use of water flows to encourage chi. The water flows need to be smooth and gentle, not like thunderous rapids
Ross, I believe the perceived problem here is the openable door at the back. If you want to see through into the garden, perhaps you could have a window directly in line with the front door? Then the back door can be off-set.
This is exactly how our house is designed. You can see right through to the back garden but the back door is on the side (unseen) by the front door. I just think its nice to have a visual of something like a glimpse of a garden when you open the front door.
Mrs B
such house design = wealth comes in, wealth goes out.
money comes money goes
no offense.
Change the door position.
Who really cares about Feng Shui? If you want to have that look through from front to back just do it. In my humble opinion atleast.
According to our feng shui Consultant (now he is actually known as a Master, so knows his stuff) the problem with straight through is that the chi is not retained for any time at all. Therefore it is not auspicious for the occupants, especially in terms of money.
3
yep sounds good make the footing bigger to to allow for the pipe in the middle
21/10/2023
Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the…
9/01/2024
3
Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit.
