Browse Forums Feng Shui 1 Nov 18, 2020 11:35 pm My property has a wall upon entering the front door, pretty close, about 2-3 steps from the front door. Apparently this is a bad Feng Shui to have a wall too close and perpendicular from the front door. What remedy can be done? How about a painting on the wall? What kind of painting? Re: Wall upon entering the front door 2Dec 16, 2020 4:23 pm ![]() My property has a wall upon entering the front door, pretty close, about 2-3 steps from the front door. Apparently this is a bad Feng Shui to have a wall too close and perpendicular from the front door. What remedy can be done? How about a painting on the wall? What kind of painting? Hi Bernard, Have you got the problem fixed? And bad things happened? If not, may be you can send me your floor plan with direction and a photo of how close the wall is once your step into your door. I will see whether I can give you some advise to solve this. Thanks for the reply and the tip to keep an eye out on rubbish dumping. When we saw that both lots on either side had begun site preparation we went and attended to… 2 2765 I can't decide what door size to put as my front door. I have a 12m wide house with a 6.35m wide garage. Ryde facade from MacDonald Jones home building Albany two. My… 0 1594 chennaiite I think what you meant to say was different size goings. In modern landscaping it's common to mix a couple of steps with big landings of different sizes. It… 7 5529 ![]() |
