Browse Forums Feng Shui 1 Nov 18, 2020 9:57 pm Is there a problem with a house (North facing) situated directly across from a Golf Course? There is a tiny body of water in the golf course at the far end near the top. The Golf Course is a Triangle shape (Aerial view). the house is situated at the exact center of the bottom side of the triangle. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ View of the golf course (across the road) from the front door Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: House across from a Golf Course? 2Dec 16, 2020 4:26 pm Is it a house you going to purchase? And will be moving soon? There is nothing wrong with the golf course, and it might help to lift your career further. Just that the direction your house(front door) is facing will not help to increase your luck. Thanks for clarifying. Sorry I misunderstood your point 7 7652 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21006 Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is… 3 1379 |
