Hi
Does anyone know a supplier that will supply these hinges??
See photos attached
Thanks
Browse Forums Windows & Doors 1 Apr 07, 2020 1:18 pm Re: Hinges need for laundry door 2Apr 07, 2020 3:20 pm Hettich or Lincoln Sentry. If you go through Lincoln Sentry it's the centre hinge on a finista BF-05 bifold door system. I'm not sure if you can buy them individually or have to get the whole set. Yours are from Hettich and should be part number 1077338 that's the plastic part. The metal bit on the other side is part number 1077339. They may be old part numbers but it should get you close. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Hinges need for laundry door 3Apr 07, 2020 3:36 pm ![]() Hettich or Lincoln Sentry. If you go through Lincoln Sentry it's the centre hinge on a finista BF-05 bifold door system. I'm not sure if you can buy them individually or have to get the whole set. Yours are from Hettich and should be part number 1077338 that's the plastic part. The metal bit on the other side is part number 1077339. They may be old part numbers but it should get you close. You're a champion thank you. Can anyone identify, or tell me where to get these 1970s hinges. Just need 4. 0 373 Wouldn't it be nice if we could see into the future? Or see pathways into the future. You could see which one had the most regret, the smaller laundry or the smaller… 7 2228 ![]() |
