Browse Forums Windows & Doors 1 Mar 20, 2020 8:53 pm Hi fellow helpful forum members, I have recently installed a double glazed windows with the intention to make my room more isolated from traffic noise. Since I've installed the double glazed windows, I've noticed a strange phenomenon that the noise blocked from inside to outside of the room almost completely, but the noise coming in from the outside is not blocked significantly enough. As a comparison, when I shout at the top of my voice from inside the room, a person on the other side of the glass would not be able to hear anything. On the other side, a person casually speaking in the outside could be well heard from the inside. I have checked for any noise leaks from the walls or the ceiling but the sound does seem to pass thru the glass directly instead of being limited to any source of leak. It's quite baffling to me and i have not found any expert advice that could possibly shed some light on this matter. Any ideas why such occurrence happen? Thank you for your response and they are greatly appreciated. =) Re: Double glazed windows issue - Noise is not evenly blocke 2Mar 25, 2020 1:57 pm No idea, but it's fascinating... "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double glazed windows issue - Noise is not evenly blocke 3Mar 25, 2020 5:36 pm My hypothesis - based on absolutely no research. What we think of as being quiet outside is not really that quiet, especially if you live in the city. And even if you live in the country there is still background noise - the wind, the rustle of foliage and the birds. In the city added to this is the sound of traffic. Go outside and listen to confirm this. Even when a shouting noise escapes from inside the house it is attenuated and has to compete with the background noise, so it is not that obvious. Inside the house is much quieter than outside. Not much of the background noise enters from outside and there is not much background noise generated inside the house. When a shouting type sound made outside some of it penetrates the house and because there is less competing background noise the attenuated shouting noise is more obvious. As I said, just a hypothesis. Re: Double glazed windows issue - Noise is not evenly blocke 4Mar 26, 2020 11:03 am willgio Hi fellow helpful forum members, I have recently installed a double glazed windows with the intention to make my room more isolated from traffic noise. Since I've installed the double glazed windows, I've noticed a strange phenomenon that the noise blocked from inside to outside of the room almost completely, but the noise coming in from the outside is not blocked significantly enough. As a comparison, when I shout at the top of my voice from inside the room, a person on the other side of the glass would not be able to hear anything. On the other side, a person casually speaking in the outside could be well heard from the inside. I have checked for any noise leaks from the walls or the ceiling but the sound does seem to pass thru the glass directly instead of being limited to any source of leak. It's quite baffling to me and i have not found any expert advice that could possibly shed some light on this matter. Any ideas why such occurrence happen? Thank you for your response and they are greatly appreciated. =) On a helpful note... can you block off the window with a doona so that you eliminate that as a path for the noise and see just what is happening. Also I suggest you download a sound meter to your phone and test your results to see if they are real. Let me know... "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double glazed windows issue - Noise is not evenly blocke 5Nov 27, 2020 6:10 am I have the same problem exactly . My personal belief is that the glass is installed wrong way around in the window . I have rung both the window manufacturer and Viridian glass and nada. They either don’t know or aren’t saying! Re: Double glazed windows issue - Noise is not evenly blocke 6Nov 29, 2020 9:24 am Roza1955 I have the same problem exactly . My personal belief is that the glass is installed wrong way around in the window . I have rung both the window manufacturer and Viridian glass and nada. They either don’t know or aren’t saying! Hi The orientation of the glass is irrelevant, it has the same noise stopping power either way. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16191 Agreed. I just found out today the certifier has not given the final sign off. 2 4072 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16126 |
