Browse Forums Windows & Doors Re: Stacker doors with 2590 ceiling height 5Jun 12, 2021 4:41 pm ECOECO 2400 high would look great I am in the same situation although I havent yet started my build. Is it structurally possible to have a 2370mm high stacker door with 2590mm ceiling? I am told there is not enough space above the stacker door for the lintel and the 2110mm high door is the only option. Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3208 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 10675 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 7298 |
