Browse Forums Windows & Doors 1 Feb 02, 2020 11:11 pm Hi guys, Currently building house with 2590 ceilings. Didn’t think how standard 2100 stacker doors would look with 2590 ceiling height at contract stage but now they are in they don’t look as good as the display homes. Does anyone have any pics of their house with 2100 stackers with 2590 ceiling? Re: Stacker doors with 2590 ceiling height 2Feb 04, 2020 8:48 am Whatever you choose, make sure the head height of your stacker door is the same as your windows.So if the window is say 600 high or 1800 high, it must be set the same height as your door. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Stacker doors with 2590 ceiling height 3Feb 04, 2020 6:45 pm ECOECO Whatever you choose, make sure the head height of your stacker door is the same as your windows.So if the window is say 600 high or 1800 high, it must be set the same height as your door. Yep our windows and doors are same height. Re: Stacker doors with 2590 ceiling height 5Jun 12, 2021 3:41 pm ECOECO 2400 high would look great I am in the same situation although I havent yet started my build. Is it structurally possible to have a 2370mm high stacker door with 2590mm ceiling? I am told there is not enough space above the stacker door for the lintel and the 2110mm high door is the only option. Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3954 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12368 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10609 |
