Browse Forums Windows & Doors 1 Jan 31, 2020 1:54 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, For at least 6 months now, four of my window frames/casings have separated from the plasterboard. They are separating at the top and the top-sides. It is happening to the one window large window on the west side and medium window on North and two small bathroom and toilet windows on North side. The greatest separation gap is about 1cm. My unit is brick on stumps stumps, constructed 1986. My windows consist of wood frames containing aluminium frames containing the glass. In addition, the toilet window casing is appears to also be moving up relative to the plasterboard as areas an area of the plasterboard that was previously behind the casing is now visible. I can tell because it is unpainted. See second picture. I have filled the gaps with foam tubing to stop draughts. Should I be worried about this? Should I get a building inspector or builder to come and assess? If so, which one? Thank you for any info or advice. Re: Help! Window casings. should I be worried 2Feb 05, 2020 2:50 pm Whereabouts are you? My first impression is that the window is not properly attached to the wall/stud. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Help! Window casings. should I be worried 4Feb 22, 2020 2:19 pm Lilac24 I'm in Melbourne. Thanks I could drop by if I am passing... just for your peace of mind. PM if you want "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Help! Window casings. should I be worried 5Feb 22, 2020 3:53 pm Top guy ECOECO. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Help! Window casings. should I be worried 6Feb 23, 2020 2:55 pm SaveH2O Top guy ECOECO. Following your lead... "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16026 hey there! 😊 so, it’s kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20922 I've decided, after a period of confusion (my building broker told me it's probably not worth it to use a lawyer, but others have said it is a must) that I definitely will… 7 27958 |
