Browse Forums Windows & Doors 1 Aug 09, 2021 11:01 am Hello. I've been inspecting around the exterior of a new house we moved into, and noticed that several of the windows have these large gaps at the bottom edges of the window frames. Curiously, some appear to be sealed all the way with the black seal material, while others fall short and thus leave a gap. See below: Gaps Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Gap covered Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is the inconsistency a sign of lazy construction? Should I seal off these big gaps or do they serve a critical function? During windy days, we can hear wind getting into the cavity of the walls that are facing the wind and causing rattling and the plasterboard to sort of flex with an audible crack/pop. I have read about a few options in sealing gaps, such as expanding foam, backer rods, and sealant. Any recommendations on best practice? Cheers! Re: Large gaps around exterior window. Fill in? 2Aug 10, 2021 11:25 am The sill flap rubber has been cut too short, it's the builder's and the window supplier's problem. How old is the house? "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Large gaps around exterior window. Fill in? 3Aug 10, 2021 11:11 pm ECOECO The sill flap rubber has been cut too short, it's the builder's and the window supplier's problem. How old is the house? The house was built in the early 2000s. Re: Large gaps around exterior window. Fill in? 4Aug 11, 2021 9:42 am Then, I doubt you will get any joy from either the builder or the window supplier.Perhaps sacrifice one piece of sill flap to fill the gaps on the others. Then find a remedy for the one, maybe an aluminium angle in black in the gap and caulked top and bottom. Just make sure you don't caulk over any weep holes that may be under the sill or you will have leaking into your home. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Large gaps around exterior window. Fill in? 5Aug 11, 2021 3:45 pm Ok thanks for the suggestion. You wouldn't recommend sticking expanding foam into the existing gaps and then sealing over what gaps remain? Re: Large gaps around exterior window. Fill in? 6Aug 11, 2021 4:16 pm basKT_case Ok thanks for the suggestion. You wouldn't recommend sticking expanding foam into the existing gaps and then sealing over what gaps remain? Sure, IF you know what you're doing. There's expanding foam that grows as it is still curing and it can destroy your window so be careful. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Large gaps around exterior window. Fill in? 7Aug 11, 2021 6:30 pm would a product like this be suitable? https://www.bunnings.com.au/sika-500ml- ... r_p1211402 I guess the key is to use sparingly so it doesn't get out of control. Re: Large gaps around exterior window. Fill in? 8Aug 13, 2021 11:05 am Sorry, I don't know, maybe ask Bunnings. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Large gaps around exterior window. Fill in? 9Aug 16, 2021 1:16 pm ECOECO Sorry, I don't know, maybe ask Bunnings. Ok thanks for your recommendations! Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much… 5 7512 7 2706 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8037 |
