Browse Forums Windows & Doors 1 Sep 29, 2019 11:27 am Hi all, I'm just curious what other people have experienced with sliding doors, and whether or not the actual sliding panel is located on the internal or external face of the door unit? Reason I ask is we get a fair amount of dirt etc coming onto the tracks, and my logic is if our opening panel was external (so when you opened it it slides on the outside of the fixed panel).....then this would seal better? Anyhow not sure what is normal, but thought I would ask you all. This is a pic of our 3 panel sliding door (2 fixed panels and 1 opening panel). As you can see the opening panel slides on the internal side tracks.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ --------------------------------------------------------------------- Check our Homeone build blog here Re: Sliding Door - single opening panel normally internal? 2Sep 29, 2019 2:58 pm Hi Darb. The sliding panel slides on the inside of the fixed panel. Once your build is complete and flywire is on and landscaping is complete the tracks should remain clean. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sliding Door - single opening panel normally internal? 3Oct 04, 2019 11:01 pm chippy Hi Darb. The sliding panel slides on the inside of the fixed panel. Once your build is complete and flywire is on and landscaping is complete the tracks should remain clean. not if it's a new estate with plenty of building still going on The construction dust from all the other houses will definitely build up there. Re: Sliding Door - single opening panel normally internal? 4Oct 06, 2019 6:11 pm Thanks guys, yes it is a new estate but as it's stage#1 and most houses are completed already we hopefully shouldn't have much more dust to contend with. I think I am just realising that sliding doors do have their negatives, especially these larger sized versions. But having said that I think I would still choose this style if I had my time over again. I would though pick a better quality window supplier next time though. --------------------------------------------------------------------- Check our Homeone build blog here I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16329 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 14028 |
