Browse Forums Windows & Doors Re: Dimensions for a replacement window 7Jul 19, 2019 11:30 am ECOECO Try scraping the surface with a screwdriver - is it plaster or mortar? It is highly likely that this is a cement render with steel ties. I suggest you find an experienced installer. Thanks Ecoeco, yes I definitely want to use an experienced installer but I would like to order/import the window ahead of time to save some dollars. The existing window has timber work all around, architraves and reveals etc, so there is no mortar near the window. I can easily measure the outside size but it is hard to work out how it will work on the inside. Re: Dimensions for a replacement window 8Jul 19, 2019 11:38 am I think the outside dimensions of the window will be the actual window dimensions. If you're going to employ an installer, you need to have him measure for the new window, that way he cannot say the window is the wrong size. I think it's a false economy to buy a replacement window from China. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Dimensions for a replacement window 9Jul 19, 2019 11:47 am I agree there is significant risk but I do want to give it a try.
I think I will employ an installer to measure, then I'll order the window and get him back in to install when it has arrived. Thanks again EcoEco. Re: Dimensions for a replacement window 10Jul 19, 2019 12:08 pm You're welcome I have no interest in your requirement, but, your risks are
"ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 2 2326 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7231 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45833 |
