Browse Forums Windows & Doors Re: WERS Air Infiltration 4May 15, 2019 10:24 am jonathan_k Thanks Ed, very informative (as always, I've read a lot of your posts). More generally, do you think that choosing a window based on the WERS Ai rating is a good metric? As a potential purchaser of your windows, I also hoped you might be able to clarify why the EcoEco casements score 5 in the WERS database? Based on your reply, I would expect that they score 0.2 like the Awning. https://awawers.net/res/reslist/ECOECO Welcome. The casement was not separately tested, so it defaults to 5 and yet it uses the same profiles and seals.. The awning tested at 0.15, I have no idea why they rounded it up because others use 2 decimal places, and the awning has appeared in WERS at 0.15. There really is not a good reason to select based upon the air infiltration alone, the star rating and the software using these data are comprehensive and include the air infiltration. You can see this in identical Uw where the stars vary. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
