Browse Forums Windows & Doors Re: Building with Wisdom Homes 4Apr 16, 2019 3:59 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Gaps around windows during build 10May 03, 2019 12:11 pm Re: Gaps around windows during build 12May 03, 2019 12:34 pm Mish018 Hi All, Is anyone at the point of their build where all bricking has finished? If so how many windows do you need angles around? We have ended up with gaps around all windows on the ground floor except for 2 living room windows and have been told we need metal angles around every window and our stacker sliding doors. Some of the gaps are so wide you can put your fist in there. Is this normal or did we just end up with terrible bricklayers? They also used a lot of chipped bricks in our build, despite there being 3 pallets of bricks left over. Sometimes when I look at our house I get so angry with myself for choosing this builder. Unacceptable. Sounds like a brickie problem, but it may be deeper. Complain to a higher level... "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Gaps around windows during build 13May 03, 2019 12:39 pm This is normal for windows with architraves. The gap is intended and is used to square the window and make it operable. There needs to be a packer behind that nail on the right (and every nail), between the wall frame and the timber reveal. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 7 3006 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 3830 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7465 |
