Browse Forums Windows & Doors 1 Aug 29, 2018 3:25 pm Drawing up plans to pass onto draftsperson to be drawn up properly and wondering how close windows and sliding doors can be spaced to each other and to end of walls/corners? What do I need to consider here? (Window height / type/ placing between studs or needing posts etc.) House will be timber on posts. Don't want to suggest plans then find out I'm going to need all kinds of steel etc to make it work. First post! Thank you. Re: Window spacing 2Aug 29, 2018 4:39 pm Don’t forget wall space in between windows and doors, and under windows for furniture placement. Window spacing 3Aug 29, 2018 6:16 pm BBJ Drawing up plans to pass onto draftsperson to be drawn up properly and wondering how close windows and sliding doors can be spaced to each other and to end of walls/corners? What do I need to consider here? (Window height / type/ placing between studs or needing posts etc.) House will be timber on posts. Don't want to suggest plans then find out I'm going to need all kinds of steel etc to make it work. First post! Thank you. I'm not a builder, but I would suggest they could be as close as the smallest stud suitable to carry the weight of the lintel and roof/second storey load above. If you have long expanses of windows or corner windows you will need a more substantial lintel and thus a more substantial stud. The one to answer the question would be an engineer who will be required to draw up the engineering plans after your draftsman has drawn up your design. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10939 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7392 |
