Browse Forums Windows & Doors 1 May 24, 2018 12:28 am My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Blinds between glass 3May 25, 2018 3:28 pm ben888 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I wonder if anyone has any experience with these double glazed windows with integral blinds, I think they're otherwise known as blinds between the glass. I saw them installed everywhere at my local hospital (and I can understand why they would be a great idea at the hospital with infection control) but has anyone used them at home? Are they worth it, or do they malfunction at times and would then be a huge hassle to fix? And I'm also thinking whether the blind itself affects the thermal efficiency of the window? They use them in hospital also because they can be obscured and require a key to alter that. So the public cannot adjust them, only staff. They work fine generally, we have a sample which had done the tour in car boots etc. for years and still works. Thermally, there is a Canadian study which shows that they improve the thermal efficiency, given the same gap size. I believe they can operate in a gap of 17mm. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9157 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 9693 |
