Browse Forums Windows & Doors 1 May 07, 2018 6:09 pm Hello, Anyone know which way the alfresco stacker doors should slide, we will have 2 single stacker doors. Should they slide toward the lhs/rhs external wall or towards the internal wall? Can I retrofit security screen doors after handover to the stackers? We have recessed tracks. Cheers Re: Stacker door questions 3May 07, 2018 6:41 pm sweetswisssteel Can I retrofit security screen doors after handover to the stackers? We have recessed tracks. You can, but the best match would be retractable screens. Problem is if you don’t plan it when the slab is laid you'll miss out on recessed tracks for the screen too, defeating the point of recessing the stacker tracks. Re: Stacker door questions 4May 07, 2018 7:48 pm arcadelt sweetswisssteel Can I retrofit security screen doors after handover to the stackers? We have recessed tracks. You can, but the best match would be retractable screens. Problem is if you don’t plan it when the slab is laid you'll miss out on recessed tracks for the screen too, defeating the point of recessing the stacker tracks. Re: Stacker door questions 5May 07, 2018 8:42 pm We chose the direction for our sets of stacker doors. My builder said he couldn’t rebate them though but someone else building with my builder had theirs rebated! Re: Stacker door questions 6May 10, 2018 5:59 pm aphsta We chose the direction for our sets of stacker doors. My builder said he couldn’t rebate them though but someone else building with my builder had theirs rebated! Re: Stacker door questions 7May 10, 2018 6:26 pm sweetswisssteel aphsta We chose the direction for our sets of stacker doors. My builder said he couldn’t rebate them though but someone else building with my builder had theirs rebated! We just chose the directions based on how the rooms would be used. This door we chose to stack them towards the centre of the house as we are building an outdoor kitchen along the wall at the right angle so wouldn’t be able to exit from the first panel if it opened that way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This door we chose to stack next to the external far corner and open from the kitchen end due to the room being a living room and not wanting to walk in front of the TV to open Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?f=31&t=89059 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7906 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12391 |
