Browse Forums Windows & Doors 1 Apr 10, 2018 8:45 am Hi there, I’ve just bought a new apartment and all the bottom bars of the top( fixed) frame are in really bad condition- is there a trick to cleaning and painting these rails? Also there is some rot in the lower parts of the frame- strata wants to fill them with putty but I feel that’s a very short term solution. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Old sash windows- how to paint + rot 2Apr 10, 2018 8:40 pm Mmou Also there is some rot in the lower parts of the frame- strata wants to fill them with putty but I feel that’s a very short term solution. With that amount of rot there would next to no thermal integrity in those frames. Personally I would opt to replace the windows altogether, and while doing so upgrade to double glazed, low-e glass and argon filled. Re: Old sash windows- how to paint + rot 3Apr 11, 2018 2:55 pm Your windows are in poor condition. I doubt if the glass is compliant. Can they be salvaged, probably yes, short term. But at some point you will be looking at replacing these windows. Firstly because the glass will likely need to be replaced, and the current sash will likely not be able to support heavier glass. And secondly because they are at the end of their life. If you and your body corporate are interested, we replaced all the windows at 23 Derby St Kew for much the same reason. All 15 apartments had their windows replaced. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 Thanks Chippy,I do have one that I levered out. I'll try to find a brand name on the windows then do some searching. Here is a photo where you can see how worn they are. 2 7959 Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3443 |
